How do i raise boost pressure with hondata
carlordinc
Post by carlordinc »
I have connect a gm boost control solenoid but i cannot get over 7psi. How do i raise the boost presue using hondata
carlord 1996gsr t25 turbo
locash
Post by locash »
Does your ecu have the PWM components added? If so, and the solenoid is set up properly, try setting it at a fixed duty cycle and keep raising the duty cycle until boost increases..
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
carlordinc
Thanks for your reply.The ecu is equipped i watch the pulse width and it records to whatever i have the settings. Also i got a gm three port which i connect according to the hondata info.If i turn off boost control it wii boost up to 15psi
Make sure you have it set to normally open.
carlordinc
Thanks for your reply.This is my complete set up.In the boost control window i have it set to normally open and duty cycle at 85%.The hose connection at the solenoid i have the pressure source coming from the intake manifold then i have a tee with one end going to the inlet of the solenoid and the other end goint to the top port of the internal wastegate actuator and then i have the outlet from the solemoid going to the bottom port.
