Reflash for K24A3 on Accord Euro or flashpro available ?
Zoro2006
Post by Zoro2006 »
Hi, I know that it's no availability to reflash K24A3 (ECU 37820-RBB-E05 ), maybe you are planing to extend FlashPro capabilities for these Engines ? O it's possible now with Flashpro ? ECU 37820-RBB-E05 is rewritable if I'am not wrong ;)
No this is not compatible with the FlashPro. At this time we do not ofer any reflashes for this ECU.
Zoro2006
Post by Zoro2006 »
Spunkster wrote:No this is not compatible with the FlashPro. At this time we do not ofer any reflashes for this ECU.
But there isn't a lot of differencies between 2007 + European Civic Type R (you have FlashPro for this). Honda Accord CL9 from 2006+ uses DBW Throttle body.
For example some people in Russia uses your Acura TSX reflashed ECU with there Honda Accord CL9. They just disconect stock Honda Accord Euro CL9 ECU and conects Acura TSX ECU. All goes without problems ;)
It would be great if you offered FlashPro for Honda Accord CL9 2006+, a lot of drivers jus waiting for this.
P.S. maybe you are planing FlashPro for Acura TSX ?
Felix
Post by Felix »
Да не, они не будут делать.. . забей...
