A question for b18c typer
taloooool
Post by taloooool »
Hi
i have civic ek 96 and i swap the engen with b18c typer jdm (98)
I searched in more than one website, I did not find anything clear about hondata ecu jdm
I took pictures for my ecu , Has been written on 37820-p73-003 and 967-106141 Please help me I do not know any hondata ecu Should be taken
I leave you with picture
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
taloooool
Post by taloooool »
dear ,
on my ecu p73
Do you mean that I should use the use s300j :?: :!:
ITR1102
Post by ITR1102 »
You can't use that P73 ecu if you want to use Hondata.
It is obd2. You must use an obd1 ecu listed on the link that Spunkster posted.
Then, depending on which ecu you use will determine if you need the S300 or S300J.
