new to hondata
darinlee
new to hondata
Post by darinlee »
i have a 95 integra with a type r swap and a few upgrades i have a type r base map but i want to make some adjustments to air fuel and ignition timing how do i go about this and what is a good air fuel mixture for the type r with bigger injectors and crower stage two cams also has bigger throttle body.
lowblow
Post by lowblow »
you have to run a wideband os sensor first
darinlee
Post by darinlee »
lowblow wrote:you have to run a wideband os sensor first
where can i get a wideband and how much do they run??
