SManager: 2D Graph is maximized; can't view tables
ITR 1102
Post by ITR 1102 »
Using Previous release as well as Beta version:
When comparing some fuel curves from different calibrations, I maximized the graph's view by sliding the vertical bar all the way to the left, covering up the tables.
The handle still shows up, but it will not drag back to the right... Tables are now permanently hidden... I have tried loading other calibrations as well as reinstalling SManager.
Ok, as I am typing this, I figured out a workaround.
If I close the tables window and reopen, it will then allow the slider to work.
(This problem only happens if the Tables window is maximized, and the slider is moved all the way to the left edge of the window.
I've changed the Table window so that the resize divider will not go all the way to the left.
ITR1102
Post by ITR1102 »
good deal; thanks
