Volts Vs injector dead time
Airwalk07143
Post by Airwalk07143 »
So i recently ordered injectors but i dont have the dead time values. Does any one know what they might be for a bosch 1600cc injector. The company i ordered them threw could only provide the number for 14 volts. 14volts= 0.850. Do i even need to know the values for different voltage?
planetspeed
Post by planetspeed »
I have the same concern for my RC860cc low impedance set.hope Tech will post Inj dead time values for the specific injector set.
The 14V value is the most important, because that is where the car spends 99% of the time at. For the other values just scale the stock values up until you get the same shaped curve. Normally the 16V value is about 100 us less than 14V, and the 10V value is almost double the 14V value.
planetspeed
I have an underdriven alt due to an aftremarket crank pulley swap which only pushes approx 12.7v at 6k rpm's..what will be my values on RC860cc Peak and Hold with resistor box?Thank you.
