How to run oil temp and pressure sensor to my s300 ???
Turbo-LS
Post by Turbo-LS »
Hey guys im stumped. I want to get an oil temp and oil pressure sensor and wire them to my hondata s300 for logging and also to display on my tunerview. I picked up an autometer full sweep temp sensor but its a resitance style sensor so i m unable to use this with the hondata. i need a voltage style sensor do they exsist for temp sensors? i was looking at the aem temp sensor but not sure it that does voltage or resistance. can someone please point me in the right direction.
Also need to know how to wire this to the ecu. i know to use the inputs d12 and b6 and setup the voltage table in the settings in hondata but do i run power to those inputs through the sensor or a ground to those inputs through the sensor. im assuming voltage but i want to be sure. thanks for any input.
__________________
ray_ycs
Re: How to run oil temp and pressure sensor to my s300 ???
Post by ray_ycs »
Hi LS,
im facing the same issue, do you mind to share how you resolved it?
