Boost cut-off missing in menu?
racing-honda
Post by racing-honda »
We have the following setup
- FlashPro serial: FP-S2K-INT-40023
- FlashPro Manager version: 1.1.5.4
- Vehicle: 2006 Euro S2000
- ECU: PCX-G12
- Mods: Vortech supercharger
- calibration file and datalog attached.
Using a Vortech supercharger it looks like boost cut-off is activated at a default 0.6 bar of boost (about 8.5 PSI) at 8100 rpm before the normal rev limiter at 9000.
No problem normally, if we could only set boost cut-off a bit higher … But it seems to be missing from the Calibration – Rev Limits menu…
Did we oversee something in the settings? Or is boost cut-off unintentionally missing from the Rev Limits menu?
You're right - there is a boost cut at 1.68 bar absolute, but there is no way of altering it. I've added it to the next release, which should be early next week.
racing-honda
Thanks!
racing-honda
Boost cut
Using FPM 1.1.5.5 boost cut is now shown in the Rev Limits menu. So that's good...
However it doesn't seem to make any difference at all wether or not we disable boost cut or wether we set a higher boost cut level.
MAP still won't go higher than abt 1.6 bar and it does feel like boost cut is coming in exactly like before in FPM 1.1.5.4.
Any ideas?
