prelude type sh ecu?
preludetyps200
Post by preludetyps200 »
I have a 99 prelude type sh with a type s h22a obd2 swap. I would like to run the s300. What ecu would i need and what things do I need to change on the engine? It is a jdm motor, tdc and crank sensors are in the distributor. Any ideas?
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
