Can't Install Driver
viperkv
Post by viperkv »
I am having a problem installing Drivers For FlashPro on my laptop.
I am running windows 7. Had flashpro on my other laptop that crashed. Its saying " windows had a problem installing driver (code 28)" . now i am trying to retune my car but i cant even get the drivers to install.
Car is a 06 civic Si
Flashpro is SN is FP-SI-10126
FlashPro Manager is V1.1.4.7 and tried V1.1.5.4 (beta full)
felysaya
Post by felysaya »
read help section of flashpro...
Sometimes Windows will not automatically install the USB drivers, or if the FlashPro has been plugged into the PC before the software is installed, the FlashPro will be disabled by Windows. In this case you need to manually install the USB drivers.
1. Open the control panel using Windows key and Pause-Break.
2. Open the 'Device Manager'.
3. Right click on 'FlashPro' (FlashPro may be listed under "ECU Hardware (Hondata) or 'Other Devices') and select 'Update Driver Software...'.
4.Select 'Browse my computer'.
5. Tell Windows to look in the FlashPro installation directory. Normally this will be 'C:\Program Files\FlashPro\Drivers' (Windows 7 32-bit) or 'C:\Program Files (x86)\FlashPro\Drivers' (Windows 7 64-bit).
6. Confirm that you want to install the drivers.
7. Windows will install the drivers.
viperkv
Post by viperkv »
that is what i did. but it still wont install. says it runs into a problem and then gives the code 28. i have tried uninstalling and reinstalling the drivers and flashpro manager. but it keeps doing the same thing.
viperkv
Post by viperkv »
its not installing on two different computers now. one is windows 7 , other is vista. could it be the flashpro?
In the device manager, what does it show up as?
