Hondata Boost Controller
blacksi76
Post by blacksi76 »
I have the blue Hondata Boost controller hooked up, and working, but I need to make sure I have the setup correct...I have a Tial 44 wastegate with a .5bar/ 7.2 pound spring...Its a normally close boost controller if I am correct so in the fixed duty cycle method, what do I set the solenoid activation pressure at?? So do I start with a lower percentage duty cycle and work my way up to determine the correct boost I am trying to reach??
a 4 psi activation pressure is ok. YOu then have to slowly raise the duty cycle and crate a chart to know what duty creates what pressure.
blacksi76
booost control
Post by blacksi76 »
ok cool, thanks, so just make a note in the notes section on my smanager of what duty cycles produce x amount of boost....thanks again and what would be the right Solenoid Frequency to enter in the Variable Frequency section??....
YOu should not need to use the variable, so just leave it unchecked.
