S300 showing 178 kpa
monkey
Post by monkey »
Hi lads. could someone tell me if all s300 ecu should have atmospheric presure sensors built into them as im getting funny reading from mine. if they should have, i will post datalogs and other info on car.
cheers.
What is the code on the side of your ECU?
monkey
Post by monkey »
Thanks for your quick reply. The code is p28 g01
The Hondata chip code is S300-2881
there is a p30 code on the connector of ecu
You will have to disable the baro error, and the injector error with that ECU.
monkey
Post by monkey »
Cheers , i will check tomorrow.
just to let you know about myself.
i built this engine for my customer over a year ago and he flew a tuner from the states to tune this engine.
Im a technician, so im good with EOBD but only now have i looked into Hondata .
I must do some more checks and will report back.Cheers
Again thanks for your quick reply and help.
monkey
Post by monkey »
Hi Spunkster.
I can datalog no problem but cannot check to disable errors you instructed me to do.
when i go to misc in parameter , i dont have option to check the listed options.
Could you point in right direction please
Thanks in advance for your time .
You must load your calibration into the software to be able to make changes to it. You then must upload the calibration to the ECU when done.
monkey
Post by monkey »
cheers. thanks for your help.
