wire connector for the ECU harness for boost solenoid?
ajpturbopittsburgh
Post by ajpturbopittsburgh »
Can't find the little wire connector anywhere that goes into the ECU harness that accepts the pin from the ECU to wire up the boost control solenoid.
Does anyone know what it's called or where I can get it. Radioshack and home depot and walmart did not have them. Are they called BEC or jst connectors? And what size are they. I understand they come in mm.
Are you looking for the connector pins?
http://www.hondata.com/civic_pin_request_info.html
