FJO Wideband Calibration
oneqkfodo
Post by oneqkfodo »
I'm running the P28 ODBO1 ecu and have wired my FJO wideband with FJO O2 sensor to the computer, but I dont know how to calibration the hondata to read the O2 sensor through the computer. I could really use some help with this problem. I have try doing searches on here but can't find anyone using the FJO system.
Bruce
It is basically the same as the PLX.
http://www.hondata.com/techplxwiring.html
oneqkfodo
Post by oneqkfodo »
Ok, thank you for info but on the wiring part of it. The fjo wideband has its own wiring harness that plugs into there O2 sensor and back into the fjo brain box. I find the plug that comes out of the fjo brain and wired it to the wire in the D10 socket of the ecu, so do I just have to follow the instructions for the S-Manager part of it?
Bruce
Team Powerline 10.76 @ 138.50
http://www.myspace.com/oneqkfodo/ V & M Racing 727-514-1983
http://www.tunedbycft.com / http://www.napaonline.com
