AFR_problem in FN2 with FPM 1.1.5.0 and above!!
mw1978
Post by mw1978 »
Hi HONDATA
I have problem with my AFR IN EURO CTR FN2 after I downloaded FPM 1.1.5.0 FPM. Problem is also in FPM 1.1.5.5
You can see on this grapf my AFR with FPM before 1.1.5.0 and FPM 1.1.5.5
The same map
Uploaded with ImageShack.us
august77
Post by august77 »
You should get a real dyno result with A/F reading.. instead of relying on the eDyno.
civicRSA
Post by civicRSA »
He is not concerned about the edyno power numbers but the AF values.
He is just using the edyno to overlay the 2 different runs so the difference in the AFR can be easily seen.
post actual datalogs showing the difference along with the calibration.
Nitro1018
Post by Nitro1018 »
Does it safe to run the car with this update? AFR really change or it's just a software problem?
Unknown without more information to see if there is a problem or not.
civicRSA
Post by civicRSA »
I noticed this when I upgraded from 1.1.4.7 to 1.1.5.0 when it was first released. WOT afr was approximately 0.5:1 richer. I have a wideband in my car as well which also read richer. I just adjusted the fuel slightly.
It is safe to run your car like that as it is richer not leaner and the difference is very small.
Nitro if you are worried send me a datalog and I will go over your tune for you again.
I have Marcin's two datalogs with me so I will post them. I was changing lots on my car at this time so 2 of my datalogs will be hard to find.
mw1978
Post by mw1978 »
Spunkster wrote:post actual datalogs showing the difference along with the calibration.
Nitro1018
Post by Nitro1018 »
News?
