Bad ecu?
met
Bad ecu?
Post by met »
I have a 97 honda civic
98 jdm gsr engine
hondata s300 v1.4.6
Car has been running great till I went to pass someone today and and it felt like someone took the gas padel away from me. I keep my original ob2 ecu with me pulged it in car runs fine. As soon as I got home from work I made a data log. I have another ecu im going to socket tonight just to rule that out. I know the code is a bit older but it has been working great.
You have no TPS reading, check your TPS sensor.
met
Post by met »
Thanks! My tps came unplugged the lock looks like it is broke. :( I put a zip tie on there untill I replace to connector.
