s200 CEL
cleantegra
s200 CEL
Post by cleantegra »
I went from a stock b16a2 to a b16a built motor with lower compression. Car started immediately once swapped but idles really high. The ECU was tuned on dyno for stock motor. It threw CEL but unable to pull the code. once I connect the 2 pin connector to check code, the CEL turns off. Everything was installed correctly.
Edit: obviously has to be re-tuned, but dont see why a CEl would come up.
Thanks in Advance.
Check the error code using the Hondata software. You may have to have the dealer/tuner do this for you.
