abs/vsa
teflonbless
abs/vsa
Post by teflonbless »
My vsa is enabled on flashpro, but it has on my dash "abs" and "vsa" , i unplugged the battery and put it back on and its still there , i know abs has to do with vsa, just wondering if its serious and has to do with the ecu
Did this happen after the car was dyno tuned? If so you may need to drive it a bit to allow it to clear the codes from being on the dyno and not all the wheels were moving.
taylorsSI
Post by taylorsSI »
same thing happened to me after it was dyno tuned. It took like 300+ miles before they went away, but they did.
FINALLYTUNED
CODE
Post by FINALLYTUNED »
JUST TO LET YOU KNOW YOU WILL GET THE SAME CODE IF YOUR FUSES FOR BRAKE LIGHTS GO OUT IN THE UNDER HOOD FUSE BOX
