launch control
michael 88
launch control
Post by michael 88 »
prejudice I could explain step by step how to put the k-manager with the launch control? I go to rev limits then under the heading launch control tick enable launch control right? then what should I put in the entries below? such items in fuel & ignition retard activation RPM or fuel enrichment or ignition retard? with regard to what is presented from rpm and speed? 5000k and 15 km / h may be okay? Thanks for the help
michael 88
can someone help me? because I just can not understand how to put the launch, and do not understand that I have to put parameters. Thank you
http://www.hondata.com/help/kmanager/re ... ch+control
The settings all depend on your requirements and your personal preference. Please read the above help file.
michael 88
ok thanks, I remain with only two questions for example, if imposed at the launch 6000k Fuel & Ignition retard activation RPM put the value of 5500 or should I put 6000? and last thing how to operate the launch control? friction drive, gear and full throttle? thanks again
michael 88
I said good or not? 'm no expert on the k-managers are beginning by
michael 88
may well go my reasoning?
michael 88
tried to put the launch control at 5500 rpm and Fuel & Ignition retard voice activation RPM 5000 I put in theory could be good? from what I understand the value of 5000 if all goes well or not?
