90 integra with hondata???
88lwbzook
Post by 88lwbzook »
hey im just wondering what itt will take to run hondata in my turbo 90 integra with lsvtec im in the process of the build and could use some help here kinda wanna run s300
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). You will also have to use an OBD1 distributor.
88lwbzook
Post by 88lwbzook »
thank you spunkster
