bossted 97 integra
bossted teggy101
bossted 97 integra
Post by bossted teggy101 »
:?: i have a 97 boosted inegra an its not runing to right they said i would need a s300 ecu is that right? its seems to miss out really bad till the turbo is spooled
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
