problems loading maps on s300j, CHECK ENGINE [urgent]
HeitorVTiBR
Post by HeitorVTiBR »
then installed in the s300j p30jdm ... I send this link to
http://www.hondata.com/s300socketing.html
CN2 soldered, etc., I did everything as required, removed j4,
I made the jumper j1 ... all right ... installation right ...
Plugged into the car, without loading map, of course, has check engine ... qnd I load a map in the car, tried tried tried ... and gave the following message ...
"Upload failed - please try uploading again"
I thought I had done something wrong, despluguei again, reloaded the map, tried again, and gave the same message ...
ie not loading the map ... Motor league, but it gets bad, why stay with the car's original map, and check engine lights up, and not anything that I put in Smanager ...
When plugged in the notebook, the drives installed correctly, I upgraded drivers and nothing helped ...
what can it be?
any help?
Use Windows 7 Ultimate
thanks,
Post pictures of your socketing that you have done, both the top and bottom of the ECU.
HeitorVTiBR
Spunkster wrote:Post pictures of your socketing that you have done, both the top and bottom of the ECU.
ok, I'll take pictures later from central ...
but something happens in the j1 jumper, I put a resistor with a black ribbon (which comes in s300j), ok right?
and when I turn the ignition key, the light of s300j give a "wink" in the green light is already lit and then the red light ... Why this happens no error in the installation s300j?
later take pictures and post here, thanks.
HeitorVTiBR
ALSO READ THE MESSAGE ABOVE!
Well, I took the pictures ...
ECU that the former owner, he had tried to "socket" her to use Chrome, but he had many skills, some just perdeno filaments, then had to retrieve it, as you can see in the pictures .. recuração think that if something is wrong, let me know ...
But like I said, the engine gives the game without hondata, but stays with check engine on, as if emerging microaerophilic map "emergency"
in the previous message I spoke of the red light in S300 ... that flashes green but then turns, and etc. ..
J1 Jumper also said that I did with the resistor that comes in s300j, you can see in the pictures ..
then follows the photos ..
[/img]
That ECU is totally screwed up. You will need to source a different ECU.
HeitorVTiBR
Spunkster wrote:That ECU is totally screwed up. You will need to source a different ECU.
then need a new ECU? jdm ECU these are almost impossible to find by Brazil ... I know that this repair was done well, why one has to go wrong because of it ... want to know if there is any error in the system ..
I need to speak a new ECU is easy, but want to work on top of that ...
known whether the jumper J1 is correct? is like that right?
thanks
