got a few questions
JDMTOKER
got a few questions
Post by JDMTOKER »
basically my car has a stutter at slight throttle. Im not sure how to post my datalog that I did. I did three different ones. every line on it is smooth except for the ignition blue colored line. when accelerating it is fine but at a constant speed and slight throttle it just stutters. kinda wierd. any help would be great. The ignition goes from 38 degrees down to 8 degrees while its stuttering, and all inbetween. thanks once again
ray
setup
95 integra 507whp
19 psi
pt67 billet wheel
stock k24a1 longblock
k20a2 intake manifold
golden eagle headstuds
vtec killer cams
You have a power supply issue to the ECU. Check the wiring is the same as a 02-04 RSX and also check the grounds are wired correctly and are making good contact to the chassis.
