towed our dragcar to the track and got a solid red light wtf
Revspeed
Post by Revspeed »
-calibration is attach
-no datalog(ecu won t connect)
-95 civic hatchback
-p28 usdm ecu
-2.0l lsvtec,1000cc injectors,gm 3bar map,obx topmount , ebay dsm/type III turbo
this would ve been our fourth attempt to run a 9.999,(best so far is 10.3@142mph)
but what a failure this attemp is
we got to the track and ecu has a solid red light on.
-all i did was download form ecu and that was the last of it.........
i tried uploading a new file but no go
-what an upset some of the guys left work early to do this and it takes us at least 2hrs to get ready
-anyone else haveing this issue?
From Help, About, what version of software are you using?
Revspeed
Post by Revspeed »
Spunkster wrote:From Help, About, what version of software are you using?
1.4.4.0
Revspeed
Post by Revspeed »
founded my problem
for some reason the s300 die
i put a new one in the same ecu
load the map and perfect.............wtf :cry:
newsoltsc
Post by newsoltsc »
I had this problem a while back when I first got the s300 unit.
When I loaded the map from the ECU I got a solid red light.
All I did was load a stock map built into the smanager and upload it to the ecu.
Once I did that I then changed it to my modified map and it worked fine.
Could be the same problem for you?
Try it in a different ecu :)
-Jose
Revspeed
Post by Revspeed »
newsoltsc wrote:I had this problem a while back when I first got the s300 unit.
i will try that today
