K20A2 Calibration required
a2k00
Post by a2k00 »
Hi, Im new to having a KPRO and would like to add a map to it.
I have a UK 2002 Honda Civic Type R K20A2
AEM CAI
Spoon N1
Spoon B Pipe
Spoon Flywheel
Stage 3 Clutch
Once I have a map I know you need to open the RSX map in notepad and change the ECU type to UK and then resave as a .cal file. Upload it.
Please can someone help? Many thanks
We do not recommend editing the calibration files manual or changing the ECU type.
a2k00
Post by a2k00 »
Spunkster wrote:We do not recommend editing the calibration files manual or changing the ECU type.
Thankyou for replying, Please can you advise why that is? From the CTROC ive been advised to load the "coid air map" and change to UK ECU, Please can you advise? Sorry for the noobish questions, Many thanks
gigaCTR
Post by gigaCTR »
because there are some parameters not completely identical.
chimp
Post by chimp »
ight click k20a2-rsx-coldair and select "open with" and choose notepad then change the ECU type from 3 to 2 and click file>save in notepad. :lol:
a2k00
Post by a2k00 »
ok... so will the "k20a2-rsx-coldair" map be fine as it is running on a UKDM K20A2 with my mods?
gigaCTR
Post by gigaCTR »
Read above. Will run, but its not recommended.
a2k00
Post by a2k00 »
gigaCTR wrote:Read above. Will run, but its not recommended.
Ok, Can you advise me as to what is recomended please?
rikitaun
Re: K20A2 Calibration required
Post by rikitaun »
a2k00 wrote: Once I have a map I know you need to open the RSX map in notepad and change the ECU type to UK and then resave as a .cal file. Upload it.
open PRB kal and PRA kal with notepad... and copy ONLY fuel,vtc and ignition tables from PRB to PRA....
keto06
Post by keto06 »
That sounds like your best option...
a2k00
Post by a2k00 »
Im really sorry im a compleate noob to this, where do i get the cals? Have you got a screenshot to explain what you mean? Many thanks
gigaCTR
Post by gigaCTR »
menu - file - open
destination is ..\your kmanager folder\Calibrations
rikitaun
Post by rikitaun »
jajajaja... ok men.. I try it...
a2k00
Post by a2k00 »
rikitaun thank you very much, Using the map as it is will be fine on a UKDM K20A2?? Many thanks once again :)
rikitaun
Post by rikitaun »
a2k00 wrote:rikitaun thank you very much, Using the map as it is will be fine on a UKDM K20A2?? Many thanks once again :)
yes men,
In Spain we have several cars running so
only check the A/F values.
