Boost control by gear with different gear ratio's
civicRSA
Post by civicRSA »
Hi.
I'm running a FG2 ecu in my Euro CTR at the moment. I'll be boosting in a few weeks.
I am running the FG2 ecu for 2 reasons.
1. ERGlift for an accurate wideband input.
2. Boost control
I understand that boost by gear will not work for now because of my gear ratio's. Can I do anything to make it work? Or can you do anything to the software to make it work?
There are some guys that are changing there gears and ratios for aftermarket products. This is something that a lot of us will want in the future.
http://www.hondata.com/help/flashpro/bo ... ost%2Bgear
Boost by gear does work, I'm not sure what you are referring to.
civicRSA
Post by civicRSA »
I understand it does work but when changing gear ratio's other than the Si stock gear ratio's then boost by gear does not work.
For example some Si owners have changed their final drives and now boost by gear does not work.
Bit like the problem we had with cruise control in 6th gear with the Euro CTR.
soxfan143
Post by soxfan143 »
If you change the gear ratios or final drive the gear selector sensor doesn't read properly. If the ECU has no idea what gear your in the BBG doesn't work.
ajpturbopittsburgh
Post by ajpturbopittsburgh »
So I'm confused....Spunkster says it works and soxfan says it doesn't. I'm boosted with BBG and would like the final drive upgrade but not if it will cause problems.
engjoo
Post by engjoo »
ajpturbopittsburgh wrote:So I'm confused....Spunkster says it works and soxfan says it doesn't. I'm boosted with BBG and would like the final drive upgrade but not if it will cause problems.
I think it works only on stock gear ratios.
civicRSA
Post by civicRSA »
This is what we need to make sure of. If I am correct then the ecu works out the gear by dividing speed by rpm.
If you change ratio's then this won't work.
ajpturbopittsburgh
Re: Boost control by gear with different gear ratio's
Has there been any resolution to boost by gear with different gear ratios and final drives? This thread needed to be brought back from the dead.
I thought you could make boost by gear work when using different gearing by going under the calibration window and adjusting to the correct ratios and final drives.
Or are the ratio's that are displayed in the box just there for reference?
Boost by gear and the cruise control use different information to determine the gear so boost by gear at this time will not work with altered gear ratios.
kartman_707
Post by kartman_707 »
then this means that i am F*****. i just bought a usdm civic si ecu and flashpro to be installed on my 8thgen asian jdm civic. I hope that hondata can come up with a sofware update to make bbg work on different gear ratios
VitViper
Post by VitViper »
Last time I checked I have BBG working in all 6 gears with altered gear ratios.
ajpturbopittsburgh
Vit what did you change in cal?
