How to disable Autotune ??
benci
Post by benci »
Hi
I'm runing B16A1 with ITB:s and use only TPS based tables for both low-/highspeed.
Does "Autotune" works if the ECU is in "Open Loop"?
I have an AEM Uego wideband-sensor to monitor A/F and could I use the standard O2 input (D14) or do I need to use one of the other pins (ELD or EGRL)?
Best regards//B.
Yes you can still use it.
You should use one of the other inputs such as ELD it is not limited in the voltage it can read.
benci
Post by benci »
Do I have to uncheck the "Disable ELD" in the Miscellaneous Options
otherwise the D10-pin will be disabled and wont read the w/b-signal or ???
Thanks for your help!
No, you should check 'disable ELD' so that the ECU does not use the input for anything other than reading the wideband signal.
benci
Post by benci »
I did all after the book, but I can't get it working.
Autotune is overcorrecting the A/F and the engine stalls aft a few minutes.
Lamba coversion is set 0V/10AF and 5V/20AF.
The AF readings are the same in the S300 parameters as in my AEM-gauge so that should be ok.
I've tried differnt values (50%, 80%, 10%, 1%) for autotune percent change per cycle.
Turned off the ignition between changes but nothing helps.
So what am I doing wrong???
Plz help!
Autotune is not perfect. It is there to help get rough fuel values. I personally do not use it. Just do a recording and then review it and make the needed changes to the map.
benci
Post by benci »
Is there a way to disable the "Autotune" function?
It seems to be engaged all the time while the w/b is connected, so how can you use the widebandsignal through the ELD (D10) for just "recording" ?
Autotune only works while you hold down CTRL-T
