two error codes i need help fixing (revised with new info)
BrockB
Post by BrockB »
serial number: FP-S2K-US-30074
flashpromanager version: 1.1.4.7
vehicle: 2008 s2000
Mods: mase engineering turbo kit
problem description: emission errors
-vehicle calibration attached
- drive 1 datalog attached
- drive 2 datalog attached
Im running a Mase kit with hondata flashpro ems on a 08 S2K.
its been running fine for several months, until recently during normal driving I have a check engine light that is on for two error codes:
1. P0455: evaporative emission control system leak detected (gross leak)
2. P0457: evaporative emission control system leak detected (possible fuel cap loose/off
The first error code is something I've been seeing for a few weeks- I tried clearing it twice and it comes back on after driving a while. The 2nd one is more recent, but I checked my fuel cap and everything is attached. There are no obvious signs of engine problems when driving.
Is this a serious error code? Can I fix it easily or is it more technical, and if so, how?
Im new with flashpro so thanks for the help guys
You should always follow the troubleshooting steps in the Helms manual for any error code.
BrockB
Post by BrockB »
where is that? (btw, a added all the info you needed from what you advised me for posting forums- this is my first post on hondata)
will the new info help?
someone from s2ki recommended i speak to someone named Justin who could help me with this problem...
BrockB
error codes fixed but would like to know how
Post by BrockB »
I finally got a hold of mase to fix the problem. I downloaded the newest flashpro, then reloaded my primary calibration and unchecked the purge/emission box with "calibration"
no error codes anymore.. :)
but out of curiousity, what does unchecking this purge/emiss box actually do to the car?
just need to learn..
thanks
More than likely you have eliminated some of yoru emissions equipment which caused the errors.
BrockB
Post by BrockB »
What does that do and How bad is this for the car? Is this a serious issue or minor?
