few questions about fts and lc
86elco
Post by 86elco »
Need help with wiring up my full throttle shift and launch control. I'm trying to set it up off the clutch and power steering. Do I just splice into the Cruise switch under the clutch and then into the wire for the power steering switch going into the ecu? Also can I run the launch control off it at the same time?
One other quick question I know the difference in the fuel cut and spark and fuel cut for the Rev limiter but whats the pros or cons for either one.
You can use the same input for both launch control and full throttle shift, but you must cut the wire that went to the original input...not just splice into it.
The ignition cut will make the tach go crazy, and also some popwel that use soem kind of wet nitrous setup would want to cut ignition becasue even if the injecotrs are cut it could run off fuel from the fuel jet.
