few questions about fts and lc
Posted: Sun Jul 18, 2010 7:00 pm
Need help with wiring up my full throttle shift and launch control. I'm trying to set it up off the clutch and power steering. Do I just splice into the Cruise switch under the clutch and then into the wire for the power steering switch going into the ecu? Also can I run the launch control off it at the same time?
One other quick question I know the difference in the fuel cut and spark and fuel cut for the Rev limiter but whats the pros or cons for either one.
