p08-j00 in s300j, doubt
HeitorVTiBR
Post by HeitorVTiBR »
Hello, I finally got my ECU p08j ... had to ask the New Zealand ...
What I realized was that the plant is already "socket" original ... already comes with 74 373 IC latch into IC4.
comes with a SIM in IC3, which probably will have to withdraw it (of course) to put the pins male s300J ..
in J4 already has a 0 ohm resistor
already comes with a resistor Identical to that provided in the Hondata s300j C27 ..
in J1 as well, since a resistor has 0ohms ..
is that right? just put the male pins and only?
Code Central is the P08-j00, stock of MT D15b
thanks
HeitorVTiBR
More Pics
HeitorVTiBR
Awaiting response from my doubts, please.
thanks
Just remove the eeprom and install the male pins and the 4pin connector in CN2.
