need advice for best hondata
joejoe54
Post by joejoe54 »
I have a 95 b16a engine recently threw a 14 code Iac or ecm... replace iac and problem still exists.....I am going to replace the ecu and was wondering which hondata system would be the best fit for my engine?
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
joejoe54
Post by joejoe54 »
thanks alot for the help =)
