car does not drive with hondata external IC enabled
h22civic
Post by h22civic »
Today I disabled the external IC by the jumper on my pr3 ecu. After doing this the car drove fine. When the hondata system was enabled previously, the car would not drive over 5mph. What most likely is the cause for this problem? Could it be that the eprom was not configured properly? This would rule out the possibility of incorrect wiring on my part since I have no error codes, right?
Thanks,
Jon
The PR3 does not have an external ROM. Then You use Hondata with a PR3 you have to take out hte stock program and put in a new chip for use with Hondata.
