P062F Code
pando
P062F Code
Post by pando »
Hi,
Last night i did a return to stock on my ECU and got the code P062F Internal Control Module EEPROM Error.
Anyone knows what does it means??
Thanks,
What version of software are you using from Help, About?
pando
Post by pando »
I'm Using Ver. 1.1.5.6
What is the code on your ECU?
pando
Post by pando »
Check Engine light comes on and under Error Codes from a datalog on Flashpro it says "P062F Internal Control Module EEPROM Error"....car runs normal and nothing sounds or feel different...
But what does the sticker on the ECU say?
pando
Post by pando »
RRB-A14???
What happens when you upload a different calibration?
netinfosolutions
Post by netinfosolutions »
In my car happen the same thing ....
When I upload a tunned map the check engine flashs 5 times. Anyone can help us?
Tks!
If you go to Online and click on Clear DTCs does the error go away?
pando
Post by pando »
Thats what I did, called a friend whos a technician at a Honda service center here and he told me the procedure they do.....They clear the DTC and check if it comes back, if it does, they change ECU and check again if nothing then its a bad ECU. If you clear the DTC and never comes back then it was probably a bad reading, nothing to worry about.
Mine is all clear now, thanks!
