Open loop over 5000rpm
XPEHODATA
Post by XPEHODATA »
SManager 1.4.7.0 and 1.4.8.0
Why S300 switching to open loop from 5000rpm with any MAP and TPS values?
XPEHODATA
Post by XPEHODATA »
B16A2
P30 ECU
Skunk2Stage2 Cams
LC1, narrowband connected to D14, wideband connected to D12
Symptoms affected with narrowband closed loop and wideband closed loop
When >5000rpm - s.trim=0
This is normal operation for it to go into open loop at that RPM.
XPEHODATA
Post by XPEHODATA »
Spunkster wrote:This is normal operation for it to go into open loop at that RPM.
WHY???????
It's not normal!
This is normal behavior. What makes you think it is not?
XPEHODATA
Post by XPEHODATA »
Hondata wrote:This is normal behavior. What makes you think it is not?
It's my normal cruising speed and rpm. I driving my car everyday more than 5000rpm for a long time. What a difference between 3000rpm or 6000rpm to forced open loop? Why I can change maximum MAP/TPS and can't change max rpm for this???
I have Golf GTi 1.8 turbo. That ECU always in wideband closed loop from factory. And have more than one targed voltage for it for some MAP values.
newsoltsc
Post by newsoltsc »
Are you always racing your car? I never reach 5k rpm when I drive unless I'm either racing; or accelerating to pass somone.
-Jose
XPEHODATA
Post by XPEHODATA »
newsoltsc wrote:Are you always racing your car? I never reach 5k rpm when I drive unless I'm either racing; or accelerating to pass somone.
No. It's my everyday car. What a problem for 5k? I have vtec point at 6800rpm and rev.limit at 9000rpm. And driving my car more than 100ml/h at highway for a long time. It's a Honda. :wink:
megomaniac
Post by megomaniac »
gear ratio change? what transmission do you have?
H22A4
turbo
S300
XPEHODATA
Post by XPEHODATA »
megomaniac wrote:gear ratio change? what transmission do you have?
Stock transmission with 4.4 final gear. Max speed 220km/h @ 8500rpm
I have a transmission with KAAZ 4.9 final gear and Carbonetics 1-5 gears for racing. Max speed 170km/h @ 8500rpm
The car worked perfectly about 5 years. I don't wont changing anything in the car. I just want true closed loop. And not understanding - why it's normal when ECU goto open loop at 5000rpm.
VT-Doo
Post by VT-Doo »
If it's normal behaviour what should the air/fuel ratio be?
Does K-Pro do the same thing and if so the same question as before; what should the air fuel ratio be? :?
Ian
Morris Mini (B18C-R)
Honda Civic Type R (FD2)
Honda Civic Type R (FK2)
jetspeedz
Re: Open loop over 5000rpm
Post by jetspeedz »
XPEHODATA wrote:SManager 1.4.7.0 and 1.4.8.0
Where did you get 1.4.8 from? i don't see a link and as far as i know 1.4.7 is latest. A link would be appreciated to post about updates.
thanks
jetspeedz
Post by jetspeedz »
Is there a post that states the updates and difference between the new and old verison?
