How to export ELD.V out from .kdl into CSV? LC-1 on PRA ELD
LK7R
Post by LK7R »
Is there posibility to export ELD.V data from datalog file into some other format? (CSV, TXT,...) If not is there data structure of the .kdl file available somewhere?
I need to calibrate my LC-1 WB with KPro that is connected to the ELD pin on ECU. So if i can get ELD.V out from the datalog file, then i will be able to compare values from it with values from the Logworks software. After merging them together i will get accurate AF to ELD.V conversion table.
Does anyone knows better way how to achieve this on PRA ECU with Innovate LC-1 WB?
Dan
I've added the ELD voltage to the datalog export csv file.
LK7R
Post by LK7R »
Thank you!
