S300j doubt on the P08-j00, AEM UEGO WB D10-ELD, and more..
HeitorVTiBR
Post by HeitorVTiBR »
My question is the following, as I said earlier, I took a P08J S300j for installation, as this topic:
http://www.hondata.com/forum/viewtopic.php?t=11536
I wondered whether to turn the AEM Wideband UEGO, in D10 for up to 5v reading, I have to remove some resistors as in the USDM ECU, which indicates this link:
http://www.hondata.com/help/smanager/in ... meters.htm
with the following sentence.
"Note, That if the ELD input (D10) is then R136 and R138 Used (U.S. ECU) May Need To Be removed"
what setting I put in VOLTAGE AEM UEGO / AEM UEGO LAMBDA CONVERSION on D10?
remembering, that is values for lambda, for use ethanol (E85) and it is best to tune up.
and the other doubt,
Radiator Fan Control in the "protection parameters"
which determines the correct temperature to drive the radiator fan, it is possible to use it in P08j?
observations: P08J, no correction originally Lambda Probe.
Thank you, I await response.
HeitorVTiBR
hallo?
You do not need to remove any resistors in the JDM ECU.
You must input the voltage conversion info that was provided with your wideband.
Fan control should also work on a JDM ECU.
