S200 ok for now?
1fast_4door
S200 ok for now?
Post by 1fast_4door »
I found a good deal on a s200. I'm wondering if it does not have the boost add-on can I still get it? The setup is a stock gsr motor intercooled with 550's and a 16g style turbo. Also is there Anything I should look for when buying a used hondata??
'98 4door GSR
On boost.
I would recommend saving yourself time, headaches and money and just get the s300 instead. It has more features, especially for boosted applications and is user tunable.
1fast_4door
Ya the more reading I do, it's better off to save up and grab a s300. I need a obd2a to obd1 harness and a p28 right? Or can I use the factory gsr ecu?
'98 4door GSR
On boost.
V-Spec race development
Post by V-Spec race development »
You can't use your stock obd2 gsr ecu, you have to use obd1 ecu like p28 etc.
