k20z2
yeuror
k20z2
Post by yeuror »
what about this engine type? is available the flash pro or anything else about programming?
What vehicle is this and what is the ECU code?
ajpturbopittsburgh
Post by ajpturbopittsburgh »
K20Z2
Found in:
2006- Acura CSX (Canada)
Displacement: 1,998 cc (121.9 cu in)
Compression: 9.6:1
Power: 155 hp (114 kW) @ 6000 rpm (SAE net J1349 Rev 8/04)
Torque: 139 ft·lbf (188 N·m) @ 4500 rpm
Redline: 6800 rpm
2006- Honda Civic (JDM)
Compression: 9.6:1
Redline: 6800 rpm
2006- Honda Accord(Europe)
Displacement: 1998 cc
Compression: 9.6:1
Redline: 6800 rpm
m_leavy
Re: k20z2
Post by m_leavy »
Can i run a turbo setup on this engine with a PRA ecu
Re: k20z2
What vehicle is this in?
m_leavy
Re: k20z2
Post by m_leavy »
Spunkster its hopefully going in a mazda rx8
Re: k20z2
Is this drive by wire?
m_leavy
Re: k20z2
Post by m_leavy »
I think it is but haven't checked yet. there are a couple of guys from Poland that have done it with the k20z4 just one is using hondata and the other is using an emu engine management system. however my polish is no good so I was looking for a pin out for a PRA ecu as I can only find picture upon picture for US compatible ecus
Re: k20z2
IF it is drive by wire we do not offer anything that will work with that in an engine swap.
m_leavy
Re: k20z2
Post by m_leavy »
all im looking for is a pin out for the pra ecu
