Knock control for Flashpro Manager 1.1.6.2
engjoo
Post by engjoo »
I see that the knock control has been change from "knock sensitivity" to "Knock Ignition limits".
How are they related ? Is there a direct correlation ?
How will it affect cals that was done in previous FPM ? Do I reload the cal in 1.1.6.2, save it and upload to FP again for subsequent upload to ECU ?
civicRSA
Post by civicRSA »
I have some questions on the new knock limit tables. For example in boost columns 11-16 the knock limit high is set to 1 does this mean that the high limit is 1 degree over actual ignition table values?
In the FlashPro manager software go to Help, then type "knock control tables" into the search tab and read the new help file about how these tables work.
