nitrous/aux123 button rate of change?
nalsv
Post by nalsv »
i was wondering.. in the AXU input button the tables for increasing or decreasing fuel and or ign timing. when i enter a value say -5, what does that relate to on the map? for bolth the fuel and ign is it a %? or is it like pressing the - (tuning)button 5 times
thanks i plan on running meth injection in the next few days this info would help
nalsv
Post by nalsv »
ANYONE?
Ignition values are exactly what you enter...not a percentage....negative values retard, positive values advance.
Fuel is just like the fuel tables. The numbers have no direct meaning so you will have to see what values are used in teh actual fuel tables and make your adjsutments carefully and accordingly. YOu can then adjsut the falues you enter in the nitrous tables jsut like you would adjust the fuel tables usign the standad CTRL-I and CTRL-D or use CTR-J and adjust the values from there.
