Flashpro not recording cranking datalog
civicRSA
Post by civicRSA »
When I try to datalog and record to the flashpro unit while cranking it stops datalogging as I crank. If I record to the laptop it is fine.
Is there a solution?
Your battery voltage is to low when cranking more than likely.
civicRSA
Post by civicRSA »
Possibly. My car was standing for 4 weeks but I have done a lot of driving the last few days so it should be charged well.
I have also relocated it to the trunk but the cable thickness is enough.
I noticed the power led on the flashpro flashes off/on once when I crank.
The problem is that you have relocated the battery. This causes a decrease in voltage.
