S300 with bosch LSU4.2 direct connection
ludoracingteam
Post by ludoracingteam »
Hi,
What happens if we plug a Bosch LSU 4.2 WB with the OEM connector plug into stock wiring?
So the WB is directly connected to S300 without WB controller.
I want to know if it's possible, and if not i want to understand why.
Because a Bosch WB is $60, whereas LC-1 kit is $200.
It will not work. You must use a wideband sensor and controller for the sensor to function. We recommend the PLX devices widebands.
dowt
Re: S300 with bosch LSU4.2 direct connection
Post by dowt »
Is this still true?
yes
