CEL problem with OBD1 P75
psyclock
Post by psyclock »
hi everyone ,
i have 92 integra b18a2 engine with turbo chargers OBD0 PR4 ecu..
last week i converted to OBD1 (OBD1 new dist. + OBD0 to OBD1 harness + P75 OBD1 Ecu + S300 Hondata)
actually nearly everything is ok . so i can change online fuel and ignition table ,i can change the kindly setting (booscut,launch,idle) etc..i can see all sensor value,engine start and walk..but ECL always is light on..i have check error code on Smanager but page is blank so i mean page says no errors, also i have try service connector short circuit but ECL is not flashing..What do you think the my problem :roll:
Regards.
It is most lilkely wiring. I owuld suggest takign it to someone with an onb0-obd1 conversion and have them look everything over.
