CEL flashes 5 times
FlashPro questions & answers specific to the FD2 Japanese Civic Type R
ModFreak
CEL flashes 5 times
Post by ModFreak »
When I flash my ride with the SI map, my CEL light flashes 5 times after the 15 secs of "diagnostics". If I use the Type R reflash map, no flashing, it just goes off after the "diagnostics".
Any advise?
It is showing the readiness codes status.
engjoo
Re: CEL flashes 5 times
Post by engjoo »
ModFreak wrote:When I flash my ride with the SI map, my CEL light flashes 5 times after the 15 secs of "diagnostics". If I use the Type R reflash map, no flashing, it just goes off after the "diagnostics".
Any advise?
Whch Si Map did you use?
ModFreak
Post by ModFreak »
Any advise?
I'm using the Civic-SI-Race-1 map with 310 injectors.
ModFreak
Post by ModFreak »
Hondata wrote:It is showing the readiness codes status.
I still don't get it. Why on a Reflash map no blinking when ready but on the SI map there is. Are the Civics in US (SI) all blinks when it is ready or is there some "diagnostics" error that cannot be understood in the error code of our ECU?
engjoo
Post by engjoo »
ModFreak wrote:
Any advise?
Does it work better for the car?
ModFreak
Post by ModFreak »
engjoo wrote:
ModFreak wrote:
engjoo wrote: Whch Si Map did you use?
Nope, don't seemed to function stably on our ride.
The calibrations are made for different markets - the JDM market, which does not require a readiness code test, and the US market, which does.
