RPM Hang on 2010 Civic Si
Posted: Mon Oct 04, 2010 12:20 pm
by mquintrell
I just purchased a 2010 Civic Si. It's a U.S. model that was built in Canada. I've read that the K-Series Reflash addresssed the RPM hang issue by implementing the "fix" Honda incoporated for the 2006 Si. If this is the case, will having my ECU reflashed help at all with the RPM hang problem on my 2010?
Thanks!
Posted: Mon Oct 04, 2010 12:54 pm
If it as a 2010 model it should have already had the Honda fix from the factory. If you want to be able to fully eliminate it I would recommend the FlashPro then you cna use MAP based tuning.
Posted: Mon Oct 04, 2010 2:21 pm
by mquintrell
Spunkster,
So what you're saying is that the K-Series Reflash reduces "rev hang" to post 2006 levels, which means it still has some of that characteristic. When I went to the "Flash Pro" page is says:
With a 100% stock Si you will benefit from:
No rev hang
Raised rev limit
Lowered VTEC point
Better throttle response
Better mid range power and torque
World Class Datalogging - which will teach you a lot about your engine.
So essentially, if I buy the Flash Pro, I receive the same benefits as a reflash, but there is NO rev hang, and I get data logging to boot.
Please confirm if this is correct.
Thanks!
Posted: Mon Oct 04, 2010 2:35 pm
With the FlashPro you get a fully tunable system that is capable of datalogging.
