Flahpro USA base maps - can they be used in euro ecu
terryl
Post by terryl »
Hi there - just wondering if anyone knows if we can use US base maps in our Euro cars - i know usa cars are 2.2 but i dont see why these maps cant be used as a starting point for us - as the map i am looking at runs same injectors i am going to be using rc650s - hondata say use the dead times they use in usa maps
Cheers .....
Yes you can, but you may get some errors due to the difference in the vehicles and you may not be able to disable the errors.
You can do this, however is not recommended to do so.
terryl
Post by terryl »
Thanks for the reply - can i ask why it is not recommended ?
Thanks again
Because you would be using US code in a Euro ECU. The hardware is different, and the behavior may be unpredictable.
S2000443
Re: Flahpro USA base maps - can they be used in euro ecu
Post by S2000443 »
What about a European start map for a rotrex supercharger on a US 06 car?
Bad_One15
Post by Bad_One15 »
how about using fuel,ignition, WOT maps of US Specs to EDM specs?
will it create some issues?
TIA...
