Need help on calibrations
ldbriggins
Post by ldbriggins »
My original motor is a ls/vtec, 9.1 j.e pistons, eagle rods, GSR head, 750cc inj, t3to4e turbo, 3inch dp, blox intake manifold my car cuts off at idle any help?
'Boom, Dunnit'
newsoltsc
Post by newsoltsc »
cuts off as in just powers down? Motor turns off?
-Jose
ldbriggins
as in motor dies
'Boom, Dunnit'
ldbriggins
hondata shows rich 13.4 then it dies, but my wideband shows like 14.. oh and i have a gm 3bar map sensor:)
'Boom, Dunnit'
newsoltsc
Post by newsoltsc »
post up your calibration
-Jose
newsoltsc
Post by newsoltsc »
Your ects get to 201*F then dies.
Also your battery voltage drops to 12v then thats when the car dies. Your fuel pump turns off.
-Jose
ldbriggins
wiht that calibration all i did was add my injectors
'Boom, Dunnit'
ldbriggins
it also says on sensors that fuel pump is off?
'Boom, Dunnit'
ldbriggins
this is my second datalog af was at 8.02
'Boom, Dunnit'
How do you have the fan control wired, becasue it seems to be related to that.
ldbriggins
I am using the stock setup and under calibration my fan is set to turn on at 198 degress?
'Boom, Dunnit'
The calibration says it is in closed loop, but when you look at the datalog there is no short term fuel trim when it starts getting lean to try to richen it up. Are you sure this is the calibration you are actually running?
