Innovate LM2 serial ( usb ) input
jordancivic
Post by jordancivic »
Is it possible yet to use the Innovate LM2 serial connection to log AFR within Smanager ?
Luke
Post by Luke »
the LM2 has a direct wideband output which you can put into the S300 and log.
take care, that you also get GND properly, since the outputs and inputs are differential.
the other way is also possible: logging several outputs (IAT;ECT;MAP; RPM) with the LM2 ;)
best regards Lukas
jordancivic
Im not talking about the analog outs, of course i can use these, im talking about a serial out so there is no issues with voltage offsets and random readings. Plug in the USB from innovate, LOG, job done.
I know this is possible, just wondering if Hondata are working on it and if/when it is likely to be available.
There are currently no plans for this.
