Does the original AJP reflash calibration still exist?
ajpturbopittsburgh
Post by ajpturbopittsburgh »
I originally went the route of having the optional reflash done on my ECU when I purchased my AJP turbo kit which cost me $695. Then after a year or so the Flashpro came out which was great. I got my flashpro for the discounted price and have since had my car tuned.
I unerstand that you probably can't add the AJP base map with the software because it was developed spedifically for the AJP turbo and may have proprietary information. But since I am one of the originall customers I would still like to have it. Would it be too much trouble to dig up the originall AJP reflash calibration and email it to me?
I liked some things from the reflash and some things that my tuner has done. It would help me to understand more elements of tuning.
The originall AJP reflash had my car's a/f ratio at idle in the low 10's but at the time couldn't adjust it because flashpro wasn't out yet. I think the car was in open loop all the time. The reflash also had a real hard vtec kick which I liked. I would just really like to see the calibration for the reflash that I purchased before.
It is not possible to use a reflash with the FlashPro as they are not compatible.
ajpturbopittsburgh
So the parameters of the reflash can't be put into the fpcal file format and opened using the flashpro manager?
I'm struggling with why this can't be done.
So if someone orders a reflash, don't you load a calibration to the ecu?
Or can you copy the pertinent values of the reflash to a calibration that can be opened with flashpro manager?
Do you flash the ECU for a customer that orders a reflash the same way that a flashpro customer flashes their ECU?
ajpturbopittsburgh
So when Hondata recieves an ECU to reflash for a customer it is a completely different process and uses completely different equipment than what's involved for reflashing an ECU via flashpro?......Really....
The reflash and FlashPro are almost completely different - they use different reflash hardware, use different binaries, different data files. Even the tables sizes are not the same. In short, it is not possible to take a reflash and then turn it into a FlashPro calibration.
